Engine Not Starting
Wanderlust
Topic author - Scurvy Dog
- Vessel Info: 1987 Carver 32' Convertible. "Wanderlust"
- Has thanked: 4 times
- Been thanked: 3 times
Engine Not Starting
Some of you are following our new boat ownership tails and the Port engine that was previously working really well is not starting! It ran last week just fine while we were running both to troubleshoot the starboard engine overheat (which is now fixed yeah!). The port engine will crank but will not turn over. The starter solenoids were green so we replaced both of them. New spark plugs, and a new ignition rotor. We originally thought the fuel gauge was reading incorrectly and it was out of fuel so they added a bit into the carbs, didn't fire up. The oil pressure read well when it was running so I don't think it seized. What do you guys think?
Chris
- mjk1040
- Been thanked: 246 times
Re: Engine Not Starting
Wanderlust
It will crank but not start.
It's a 1987 so I'm guessing it has points.
Chris
- Has thanked: 469 times
- Been thanked: 1765 times
- Been thanked: 601 times
for combustion you need compression fuel /air mixture and spark. If you put some fuel down the carb and it didn't even try to fire its time to look at the spark. Even if you had a bad cap and or rotor, it would most likely give you a sputter or more. Check the small wires to the coil. with the ignition switch on you should get 12 +/- volts. Not knowing your mechanical abilities, and not wanting to lead you to a good shock I will stop here. Let me know what you know and we can go further.
- mjk1040
Users browsing this forum: Google [Bot] and 18 guests
