ac pump cleaning
racerx
Vessel Info: Carver 380 Santego 1998
ac pump cleaning
Postby racerx » August 2nd, 2016, 5:02 pm
Do any of you remove your inlet lines to ac pump and clean them periodically,if so what is the best cleaner? Vinegar etc. I am in freshwater. Thanks for your replies.
Re: ac pump cleaning
Postby tomschauer » August 2nd, 2016, 7:40 pm
I clean my strainer a couple times a season but have never needed to clean the lines.
Postby Viper » August 2nd, 2016, 9:54 pm
I never clean lines. Strainers checked at winterizing time but it really depends on the conditions of where you boat. Why are you asking? Are you having a problem with the lines or the AC unit?
racerx
Postby racerx » August 2nd, 2016, 10:08 pm
No problems the boat in the dock next to me was having problems he took his pump apart and it was really nasty looking just trying to be proactive.
Postby tomschauer » August 2nd, 2016, 10:10 pm
Maybe he doesn't have a strainer, or had the ac running when he was sitting on the bottom??
Reelpriority
Vessel Info: Carver 356 Aft Cabin
1999
Miss Judy, Murrells Inlet, SC
Been thanked: 4 times
Postby Reelpriority » August 2nd, 2016, 10:15 pm
Hoses to A/C pump and manifold are removed and high pressure dock water is used with dock hose, adaptor and clamp. End result is a complete flushing of lines and evaporator coil which pushes any fine accumulated sediment out of the system. End result is improved cooling temperature.
Need to flush hoses varies by area and water conditions in the marina. Barnacle buildup can also be a problem in warmer salt water areas. There are flush solutions to address barnacle build up using a small re circulating pump.
MISS JUDY
Murrells Inlet, SC
Been thanked: 248 times
Postby mjk1040 » August 3rd, 2016, 2:11 pm
Sea Flush has a few you tube videos on this procedure for cleaning the AC unit system and also your engine cooling system. MIKE :down:
racerx
Postby racerx » August 3rd, 2016, 10:21 pm
Thanks for the replies you are all very helpful.
