2000 carver 356 aft cabin batteries
- mjk1040
- Been thanked: 248 times
Re: 2000 carver 356 aft cabin batteries
- mjk1040
- cpoint
- Has thanked: 208 times
- Been thanked: 32 times
- mjk1040
I agree with Mike; it's an easy install and it should also be noted that most marine units are smarter than household ones in that they learn patterns of activity in hopes of minimizing nuisance alerts. The low voltage chirp is a bonus feature that will attract/alert others in the marina that there is an issue during your absence.
Mike also brings up a very good point regarding generator usage. Non-use of any engine is the worst thing you can do, it's an engine killer. Run it at least once a week under load and bring it up to normal running temp for a while. Your genny will love you for it.
- cpoint
- cpoint
Viper wrote:Source of the post As long as the batteries are charged or your charger is on while the generator is running, and all systems are functioning properly, you should not have a low voltage issue unless your loads are drawing more than you're charging.
Thanks viper. Still having engine issues, so I can not test out this issue. But I did look at the detector, all 3 have green power light while on dock. So I believe detectors are fine. I am pretty sure it is power issue. Boat yard will be checking out the engine issue Tuesday, I will have them check out the batteries, as well as alternator, if it is charging issue while generator is off and engine is running. The batteries are NAPA Auto batteries currently (not sure how old or new they are) Most likely I will end up replacing with marine batteries.
- jmm48m60
- Vessel Info: 2002, carver 356 aft cabin, Crusader engs, hurth transmissions
BOAT NAME 'TANKRR' - Location: virginia
- Has thanked: 2 times
- mjk1040
