Carver 405 MY swim platform storage box
Re: Carver 405 MY swim platform storage box
Postby mjk1040 » February 11th, 2017, 5:48 pm
Can you push some mesh through , then pull it back to the hole with a string or wire attached and add your filler? Just a thought. Mike
Been thanked: 1310 times
Postby bud37 » February 11th, 2017, 6:57 pm
dsolo wrote:Source of the post Any suggestions on how to plug the hole with no backing? There is only fiberglass with nothing behind it. All other holes are blind and will hold the epoxy. Thanks Dan
How deep is the hole.?...I have filled holes with hardwood dowel soaked in resin then just clean up the outside and finish how you want.....just make the hole the same size as the dowel should be interference enough to hold in place.... :beergood:
dsolo
454 EFI Crusaders
Name: La Belle ll
Been thanked: 25 times
Postby dsolo » February 11th, 2017, 8:32 pm
Wayne162 don't get concerned about the amount of difficulty. I have arthritis and struggle with any activity requiring some hand strength. the project should go smoothly using a good putty knife and a mullet to break the 3M chalking between the outer and inner storage box. Use a 1 inch putty knife with a rounded edge and come in at an angle that allows the knife to penetrate the seam about a 1/2" and tap the knife along the seam. The knife should follow the seam and break the bond as you go. I had some help breaking the final bond with two of us pulling the lid and inner liner from the outer. Once removed you will see the 10 screws attaching the outer box liner to the swim platform. Use a hand screw driver to remove the screws. Don't make my mistake and use a power driver. You get a better feel for the screw in wet rotten wood. I started drilling over size holes with a 3/8" hole. many of the holes were fine and had good wood chips, three ended up having 1/2" holes drilled with wet wood. I used a 1/4" dremel ball bit to under cut the wood below the fiberglass. I am giving the holes a couple weeks to dry before applying epoxy putty to the holes. Three of the holes will be flooded with a hardener before filling with putty. I have asked my surveyor to come by with his moisture meter to test. Structurally the swim platform seems fine, I see no weakness in the platform, I think I caught in time. Special thanks to g36 for sharing the problem. Dan
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
Postby g36 » February 11th, 2017, 9:04 pm
Your welcome Dan . I am very glad you looked into this. I was also fortunate that only a small amount of localized damage was found on a few of my holes. I hope others that have this storage box on their carvers will check theirs. Carver seemed to have skimmed on this. imo
dsolo
454 EFI Crusaders
Name: La Belle ll
Postby dsolo » February 22nd, 2017, 10:29 am
Bud37 used your idea on two holes. Inserted epoxy and 1/2" dowels. Let dry and drilled a blind hole and filled with epoxy putty. Worked great. Thanks
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
jcoll
Has thanked: 18 times
Been thanked: 18 times
Postby jcoll » February 22nd, 2017, 2:26 pm
I've heard of swim platform problems on these boats but no one could explain why. I now know. I also know my project list just grew! Bit of a poor choice on Carver's part not sealing the screws IMO.
Postby bud37 » February 22nd, 2017, 4:41 pm
dsolo wrote:Source of the post Bud37 used your idea on two holes. Inserted epoxy and 1/2" dowels. Let dry and drilled a blind hole and filled with epoxy putty. Worked great. Thanks
Glad to hear it worked for what you wanted, thanks for letting us know....... :beergood:
