Water leak around dripless bearing
- crquisto
- Vessel Info: 2000 Carver 406 Aft Cabin, twin 7.4 gas Mercruisers - Flyboy II
- Has thanked: 2 times
- Been thanked: 3 times
Re: Water leak around dripless bearing
- Been thanked: 1113 times
You need to find out if the unit is cracked. It should not leak there. The gap isn't the cause. Try this; remove the water hoses, loosen the forward clamps just enough so that you can rotate the forward assembly. You should be able to feel with your hand where the housing ends in the tube by squeezing the blue hose. Get an approximate measurement of that length. Slowly rotate and pull the assembly out of the blue hose. Stop every half inch and rotate while you inspect the housing for cracks. Pull an additional half inch and inspect again until you feel you're close enough to the end of the tube/bearing. Don't worry, while water will come in if the assembly accidentally comes all the way out, it won't be so uncontrollable that you wouldn't be able to put the assembly back in and stop the water, just be prepared in case it does happen. The following is a newer style but the inside where it clamps should look about the same:
https://www.tidesmarine.com/index.php?route=product/product&path=414_62_417_544&product_id=783
- crquisto
Viper, I have squeezed the blue tube and can't discern a place where the housing might end. Perhaps if I begin to pull it out I'll be able to feel it. I guess I don't understand how the housing is supposed to help keep water out if it just pushes up against something else to seal on the back end.
Here's a little more info that may shed some light. It came out in my survey three years ago that this boat was run aground twice by previous owners. Once required starboard transmission replacement and the other time required port transmission replacement. Yet the logs look the same indicating the different mechanics went to the effort of matching them or they just weren't replaced. Maybe that port log is the original and it is damaged as I have always gotten a little water in that area when I run hard.
- SanJuanDreamer
- Has thanked: 1 time
- Been thanked: 21 times
I don't know what to expect from dripless but from what I understand, they're a little more forgiving.
It seems to me, you may want to consider hulling and pulling the shafts for inspection as I don't think there should be that much activity you going through.
Just my two cents of experience. I may deserve change...
crquisto wrote:Source of the post....but I'm pretty sure now that the water is entering from the prop end of the shaft......
Don't know what you mean here. Are you now saying that the water is coming from the front of the unit between the shaft and the seal?
crquisto wrote:Source of the post ....I don't understand how the housing is supposed to help keep water out if it just pushes up against something else to seal on the back end.....
That's not how it seals, that's why the gap doesn't matter. At that location, the seal is simply made by tightening the hose onto the housing that's inside the hose not at the end edge of the hose. The clamp is forcing the hose down onto the housing preventing water from getting through.
I'm still a little iffy on whether you are positively sure of where the water is coming from. From your previous description, the water is not coming out of the front of the assembly where the shaft exists it but from around the hose, is this correct?
Not uncommon for dripless logs to be overlooked in an impact repair which is a no no because they are not bullet proof. They're more fragile than a traditional packing log IMO.
- crquisto
- crquisto
