Exhaust risers
jcoll
Has thanked: 18 times
Been thanked: 18 times
Re: Exhaust risers
Postby jcoll » February 11th, 2018, 11:44 pm
Thanks I too tried that. All the listings, including ebay are BARR castings not Crusader, at least all the ones I saw were. It appears Crusader doesn't sell the 98126 anymore and I'm pretty sure OSCO doesn't either. From what I can see BARR is the only manufacturer making them. I think the "new style's" design helps prevent water reversion which is why it's an inch and a half taller. The 98126 -"old style" is a low profile. I'm not really a fan of BARR but I'll use them if I have to. I'm just trying to find out if the new style will fit my boat with out having to drive an hour to measure it out. Thanks for your reply.
jcoll
Re: Exhaust risers
Postby jcoll » February 11th, 2018, 11:53 pm
I did that too. All the listings I saw were BARR castings (aftermarket) not from Crusader. Looks to me like the only one making the 98126 "old style" is BARR. I'm not really a fan of BARR but I'll use them if I have to. I believe the "new style" is cast to help prevent water reversion in the exhaust system and that's why they're an inch and a half taller. I'm wondering if anyone has used the new style - R029015 in a 355 model. I'd rather go with them. Thanks for your reply.
Has thanked: 598 times
Been thanked: 1281 times
Re: Exhaust risers
Postby bud37 » February 12th, 2018, 9:52 am
I surely don't want to sidetrack this, just a question.....do you know who the original supplier was to Crusader or did they have their own cast proprietary.
jcoll
Re: Exhaust risers
Postby jcoll » February 12th, 2018, 1:19 pm
I don't know who cast the originals. I would suspect they farmed this production out and they don't do it in-house. This is purely speculation though.
Been thanked: 246 times
Re: Exhaust risers
Postby mjk1040 » February 12th, 2018, 5:19 pm
I might get to the boat Wednesday and maybe I can take a measurement 4 u. 1.5" isn't a lot but if we r close to the floor grid it could be an issue. Especially if future aligning of the engines was in order? I'll let u know what I find.
jcoll
Re: Exhaust risers
Postby jcoll » February 12th, 2018, 6:14 pm
Thank you. That will be a big help! I'll check back later in the week.
Has thanked: 469 times
Been thanked: 1765 times
Re: Exhaust risers
Postby Viper » February 12th, 2018, 8:30 pm
They are in Canada but try Anthony Keats Marine. They may be able to steer you to a source in the States. At the very least, they'll probably be able to answer your questions re OEM parts.
http://www.anthonykeatsmarine.com/
Re: Exhaust risers
Postby mjk1040 » February 14th, 2018, 7:35 pm
Well there seems to be room for and additional 1.5" riser height. But if your engines after mounting and alignment are higher than mine are presently sitting, its going to be tight. If you go with the higher riser you may end up with the riser now inside the floor grid system and if the taller riser happens to be a little bit wider, you may have your new riser rubbing on the floor grid system.
jcoll
Re: Exhaust risers
Postby jcoll » February 14th, 2018, 8:12 pm
mjk1040 wrote:Source of the post Well there seems to be room for and additional 1.5" riser height. But if your engines after mounting and alignment are higher than mine are presently sitting, its going to be tight. If you go with the higher riser you may end up with the riser now inside the floor grid system and if the taller riser happens to be a little bit wider, you may have your new riser rubbing on the floor grid system.
Thanks, that's good info. & I appreciate your effort. I contacted Viper's recommendation and they indicated they can get OEM Crusader parts. I'll follow up after everything's been completed. :down:
Re: Exhaust risers
Postby Viper » February 14th, 2018, 9:53 pm
Are you close to the great lakes?
