1998 Crusader 350 XLi - RPM Fall-off until it dies after 45 minutes
Been thanked: 652 times
Re: 1998 Crusader 350 XLi - RPM Fall-off until it dies after 45 minutes
Postby g36 » June 4th, 2021, 11:42 pm
The oberg round ufo filter/ screen is the 1st filter the fuel from the tank will come to. It is a 28 micron filter if I remember. it will be mounted low , the next in line which is on my xli's, a racor water separator like this a 10 micron...https://marinepartssource.com/fuel-filt ... uFEALw_wcB. The one at the throttle body is the metal cannister I referenced earlier also a 10 micron filter
Capn Crunch
Vessel Info: 1995 Carver Santego 310
Crusader 350XL injected, Hurth Inboard
Location: On the Mighty Columbia River in the Pacific Northwest
Has thanked: 87 times
Been thanked: 7 times
Postby Capn Crunch » August 2nd, 2021, 12:19 pm
Hi all, I found this thread searching for a fuel pump part # - I have 1995 TB350 XLi engines, can't seem to find any part #'s specifically for Crusader, anyone out there have a good #?
Specifics are 1995 Santego 310, TB350Xli modeled engine, serial # 95059. What I thought was the correct part # turns out to have an extra exit port (vapor return) that my current fuel pump doesn't have. (Crusader #23234)... my pump looks more like Sierra 18-7330, but I have no idea if the psi is correct as that part is listed for volvo penta if Im not mistaken.
