Sooo im a complete DUMBA$$
- ataylor233
- Has thanked: 83 times
- Been thanked: 7 times
Re: Sooo im a complete DUMBA$$
- Has thanked: 602 times
- Been thanked: 1311 times
Ok, not bad,.... how is the head and cylinder wall? ....If you can , vacuum out the big bits stuck between the piston and the top ring land if you can take some time , it will pay off and don't forget the sharp edges on the piston top.
- Been thanked: 1113 times
I've seen much worse pistons come out of very well running engines.
- ataylor233
Curious, hot thick in thou was that washer and did the plug survive ?
- ataylor233
bud37 wrote:Source of the post Yep, doesn't look bad at all...you may have dodged one here except for the labor...good thing you got it off fast...if it were mine I would remove the valves in that cylinder and check for bent/straight while the head is off especially the intake with the impact marks......it takes very little bend to create a sticky noisy valve train and inspect the seat.
the plug survived not sure how thick the washer was but it wasn't huge . i plan on go over the valves shortly . i work from home so i just took my laptop to the boat along with the tools and i was good to go … now I'm going to pick up gaskets then i will slap her back together if all is good with the valves.
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
