I'll post the computer readings, fuel pressure and compression readings in the morning...busy schedule today.
Thanks for all of your wisdom.....
405driver wrote:Source of the post Top
405driver wrote:Fuel pressure was about 40 with the key on and engine off. Leak down was negligible. In idle, the FP was about 40 with rapid fluctuations from 37 to about 42.
405driver wrote:Source of the post So, if I understand you correctly, when we checked the fuel pressure with the vacuum hose off, it read to high (40). Then when we reconnected the hose, the fuel pressure dropped down to about 30.
405driver wrote:Source of the post.....I have considered doing the valves as the visible slick on the water might be oil leaking down a valve guide......
