110 outlet
bobfino
Vessel Info: 2005 Carver 396
Been thanked: 2 times
110 outlet
Postby bobfino » November 18th, 2014, 2:42 pm
Hello, unfortunately starting to get cold and this is my first boat with diesels. In case we get that nice winter weekend I do not winterize the boats I had in the past. I just made sure heat was available by small ceramic heaters both in the engine area and the salon. On this boat there is no real convenient way to run a power cord up to a outlet. The question I have since it is diesel is there a reason I should not install a 110 outlet in the engine area. I have been on larger boats that have them so I thought I would ask. Thanks
AaHubb
Vessel Info: '99 404 CPMY
my twin diesel pusher
Has thanked: 15 times
Been thanked: 61 times
Re: 110 outlet
Postby AaHubb » November 18th, 2014, 8:28 pm
That's what I did. I installed a new breaker in the 110vac panel and ran marine grade 12/2 w/ground romex to an outlet in the engine room (ok, crawl space). I used an outdoor rated jbox and cover to keep out moisture.
'99 404 CPMY
SeaDragon
bobfino
Re: 110 outlet
Postby bobfino » November 19th, 2014, 2:08 pm
Thanks for the reply, that is what I was thinking as well.
