Carver 3807 TV antenna
Topic author
Bees Nest
Vessel Info: 1990 3807 Aft Cabin
Postby Bees Nest » November 24th, 2014, 11:53 am
I'm a new owner of a 1990 38' aft cabin. Is there a factory installed TV antenna? If so, where is it located? If not, where does the antenna wire into the amplifier go to?
Re: Carver 3807 TV antenna
Postby g36 » November 24th, 2014, 3:14 pm
i dont have a 3807 but my carver 405 is fairly similiar although abit newer. my factory antenna is located in the forward storage area of the flybridge which hangs over the windshield which is below, and located on the stdb side. to see mine you slide open the forward strorage door stick your head in and look, yours might be similiar. have you looked closely in that area?
Low Flyer
Vessel Info: 1998 Carver 355 MY
Mercruiser Bluewater 454's
Been thanked: 7 times
Postby Low Flyer » November 26th, 2014, 2:13 pm
My 355 has the TV antenna in the forward brow area also. I do not know where the amplifier is either.
Have tried following the cable but do not find it plugged in anywhere after the splitter on the side cockpit wall. No signal on any of the TV's.
Anyone else find it?
"Water Wings II"
1998 355 Aft Cabin
