Mariner flooring project
- Agriman
- Vessel Info: 1998 Carver 350 Mariner Twin 454 Crusaders
- Has thanked: 5 times
- Been thanked: 5 times
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
Re: Mariner flooring project
First, I went to the local dollar store and bought a pile of white 3x4 sheets of cheap bristol board (construction or project paper). I then laid it out all over my existing floor, trimmed the edges and used duct tape to join the pieces together. I removed the hatches in the floor and used an exacto knife to cut the holes into the bristol board where the hatches were. I used the exacto knife to cut around the bulkeads and built in furniture.
When I was done, I had an exact template of my floor. I then took this template home and stapled this template to 4x8 sheets of thin plywood and cut the plywood as per the template. I cut and glued laminate flooring ontop of the plywood, leaving the openings for the hatches clear. The I also cut a piece(s) of plywood to fit the hatches and cut and glued the laminate to the pieces of plywood on the hatches.
When finished, I was able to put the run of plywood/laminate flooring into the back of my truck, supported it with 2x4s and transported it to my boat. With the help of a buddy, I turned the floor template on its side and carried it into the cabin. I flipped it over and onto the floor and it was an instant perfect fit. The hatches were then dropped down into the holes. I screwed the floor down and was done. The beauty of doing it this way was that i could do all of the construction at home an dthe actual install at the boat was under 20 minutes.
Hope this helps!
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
- Agriman
Thanks, Agriman
