AC on 3807 has been fited with thermostats, how to start pump first.
- Been thanked: 654 times
Re: AC on 3807 has been fited with thermostats, how to start pump first.
does your thermostat look like this?
http://www.tampabaymarineair.com/mediac ... ort-io.jpg
if so have you looked at the programming set ups to verify how your thermostat is programmed. there are several paramters that can be set including it being set to either only heat or cool. only or auto changeover. this can prevent this compressor from coming on and also compressor time delay. if you dont have the small card with the instructions and settings check your manual or google the passport manual if not i can email you this. it might be worth a shot. i set mine to heat or cool only and change it for summer or winter . easy to check and program.
i just googled it for you
here you go
http://www.tropicalmarineairconditionin ... rt-I-O.pdf
also if you look at p12 you can set the pump to cycle on to verify the pump i would leave it in auto to cycle with compressor but you could change it to temporary verify pump output. again if there is more than 1 ac unit and only 1 pump there will be a pump control/relay box somewhere.
http://www.charlesindustries.com/images/gr_adaptb.gif
- justtls
- Has thanked: 6 times
- waybomb
- CYO Moderator
- Been thanked: 490 times
Users browsing this forum: No registered users and 87 guests
