ac water strainers
Topic author - Scurvy Dog
- Vessel Info: 1984 36 ft. carver v3607 aft cabin
1977 30.ft. pacemaker
1973 30 ft Burns craft house boat
ac water strainers
- waybomb
- CYO Moderator
- Has thanked: 58 times
- Been thanked: 458 times
Re: ac water strainers
I don't have a 36 aft, but had a 42 aft and now have a 36 Mariner. There's only one pump servicing all the condensers.
You may ask around to see if anybody you know has a clamp on ammeter. They can instruct you how to use it. It is possible the unit breaker has failed, the current being used by your salon ac is higher then the main. It's possible. Check amp draw at start and run, and compare to breaker ratings. If less than the unit's breaker, I would then agree it
is the main breaker needing replacement.
If an original ac unit, and loud and vibrating, I might consider the unit is bad or going bad.
Having said that, I installed a new Webasto in my forward cabin. The original is directly under the bed. The Webasto's air flow through the vents is louder than the motor/compressor. If you find you have to replace the unit, I recommend Webasto. I have no financial interest in this recommendation; I just really appreciate the Webasto.
- Vessel Info: 1986 Carver 3227 Convertible
- Has thanked: 461 times
- Been thanked: 1725 times
- Vessel Info: 1986 ACMY 4207, Twin 454, with previous owner's self righteous modifications.
- Has thanked: 5 times
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
Users browsing this forum: No registered users and 61 guests
