Engine Water Pump - Impeller Replacement
Has thanked: 427 times
Been thanked: 1557 times
Re: Engine Water Pump - Impeller Replacement
Postby Viper » August 13th, 2015, 9:42 pm
Ya I have to agree Fred. I don't like the 180. For the price these days, get yourself a temp gun and check a few areas on the engine, especially at the temp sender. Expect the temp to be less than the gage reading as the sender is emersed in fluid but I wouldn't expect to see it off by 20 deg. If it measures close to 180 then I'd say you need to dig deeper. You also have another engine to can compare reading with at key points. These guns are a must to keep on board IMO. And yes, there is nowhere for antifreeze to go except into the bilge or an overflow bottle, oil pan, or out the exhaust! Are your exhaust manifolds closed cooled or raw water cooled?
Topic author
mrsparkj
Vessel Info: 1987 Carver Aft Cabin
Has thanked: 3 times
Postby mrsparkj » August 14th, 2015, 8:05 am
Thank Fred. Appreciate the info and helping me walk through this. Will see what the mechanic has to say.
Scott
Topic author
mrsparkj
Postby mrsparkj » August 14th, 2015, 8:08 am
Viper, Raw Water cooled. Pump brings water in from bottom of hull, sends to heat exchanger on back of engine, then water out the exhaust. Copy the temp gun, looking online at amazon (come to love that site for boat supplies).
Thank you for your help!
Scott
My Jurisdiction
Vessel Info: 1981 3007 aft cabin
Has thanked: 19 times
Been thanked: 3 times
Postby My Jurisdiction » September 11th, 2015, 11:31 am
I noticed impeller chunks in the starboard heat changers temp still fine 160 range. Going to replace both at dry dock this next spring.
JimnJudi
Vessel Info: 1997 350 Mariner
Been thanked: 2 times
Postby JimnJudi » December 2nd, 2015, 7:59 pm
II had a similar problem with Crusader Model 270's from 1986. Starboard side was 160, port was 180. Added a little antifreeze about once a month. Turned out to be a small leak in the heat exchanger.
Hope you found and were able to fix it earlier this summer.
