1987 36 Mariner - back to life!
- waybomb
- CYO Moderator
- Has thanked: 66 times
- Been thanked: 482 times
Re: 1987 36 Mariner - back to life!
The handle comes out with a long hose, the mount can be adjusted up our down. I did disassemble it and cut the height down a bit.
- waybomb
- CYO Moderator
So we took it out yesterday and the starboard engine sputtered and died a few times and I couldn't get it over about 2000 rpm. Pix below
So today I pulled the carb filetr, clean. Pulled the canister filter, clean. Pulled the anti-siphon valve - completely fouled with a grease like substance. The hose at the fitting also had that mung. Cleaned the valve, cut some hose back, flushed the hose with some carb cleaner, and started the boat up. All is well, but alas, windy and waves. So maybe next week we'll try again.
Pix from the first time out on the lake in about 11 years or so.
And finally the Manitowoc unloading stone. I always wondered how they tied off, and we learned yesterday. There's a boom on the front of the boat. One crew member grabs the line, and they swing him out and down to land. Two crew did this. Awesome. Probably not OSHA compliant!
knappjd
- Vessel Info: 1986 3607
- waybomb
- CYO Moderator
- Seif911
- Captain
- Vessel Info: 1977 Carver Mariner 33'
- Been thanked: 4 times
Steve
- waybomb
- CYO Moderator
Wish me luck. Looks like lots of little balls and other parts are going to fall out.
If anyone has rebuild instructions please forward them on.
- waybomb
- CYO Moderator
Last report was on the Hynautic system - I bought the h50 rebuild kit, and took it all apart and rebuilt it. This time though, bleeding the air out only took 50 turns or so.
The boat has been, running fine, etc. The tachs are screwed up, so I need to replace the gage set. I haven't finished the install on the cabin stereo yet, but that's be done shortly.
Other than that, all is still working and working well.
- Has thanked: 470 times
- Been thanked: 1768 times
- waybomb
- CYO Moderator
OEM Teleflex
- throwback2
- Vessel Info: 1987 Carver 28 Voyager,twin small blocks,1991 Shamrock,350 Chevy now.
and a few other water toys - Has thanked: 8 times
- Been thanked: 23 times
