Changing Oil
- Jangocat
- Vessel Info: 1975 28' Carver Santa Cruz, Flybridge,twin 302 Waukasha inboards, shaft drive
- Been thanked: 9 times
Changing Oil
- waybomb
- CYO Moderator
- Been thanked: 490 times
Re: Changing Oil
On my two previous Carvers, the engines were Mercruiser with the dipsticks having threaded ends on them so a oil sucker simply screwed on like a garden hose.
I use a "Topsider". I warm the engines up first so the oil flows. While the oil is being sucked out, I change the oil filter and the two fuel filters (canister and carb bowl)
On the Cougar I have adapters on the oil pan for sucking out the oil from the bottom through a big hose. But those engines each hold 14 quarts!
If you can get to the bottom of the engines easy enough, you may want to install the drain plug / hose adapter - the oil suxck out much faster through the bigger hose.
Spencer Howard
Re: Changing Oil
- feeez
- Has thanked: 52 times
- Been thanked: 66 times
Re: Changing Oil
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
Re: Changing Oil
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
Re: Changing Oil
