How the heck do you repower a 1994 39 Cockpit MY?
tonyiiiafl
Has thanked: 601 times
Been thanked: 193 times
Post by tonyiiiafl »
As I was laying down last night to sleep and thinking of getting HOLODECK down here from Maine in the spring, a thought popped into my head.....how the heck would one pull and replace an engine if it ever needed to happen in this type boat? There is NO straight access into the salon area, it is either up a set of stairs or down a set of stairs. OK, I am ready for any answer anyone can give me. !!!!! :censored:
Been thanked: 493 times
Re: How the heck do you repower a 1994 39 Cockpit MY?
Post by waybomb »
Through the windows or through the door.
Some disassembly required......
Lyndon670
Vessel Info: 2000 Carver 506
Volvo TAMD74EDC
Has thanked: 124 times
Been thanked: 140 times
Post by Lyndon670 »
Straight out the side - cut a hole big enough for the engines to slide out and then reglass it when the new engines are in. Like you would with an impact repair.
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
I think it can be done both through the companion way door and through the aft cabin door. I believe going through the aft cabin requires cutting into the wall between the aft cabin and the salon. It's a bit of work but I recall hearing that going through the companion way door isn't as cut and dry either, even with the engine torn down to just the block. I just can't recall if it was a 39 that this related to. Either way, you're dealing with stairs but that's not as bad as gaining a wide enough opening.
NTL
Vessel Info: 1990 Carver 3608
Post by NTL »
I have a 1990 3608. I had to replace the starboard motor. We took the railing off and went through the window. You'll need to strip the motor down (pull oil pan etc). If you want to see pictures or have questions please feel free to email me. It's a job but very doable. Best of luck.
NTL wrote:QR_BBPOST I have a 1990 3608. I had to replace the starboard motor. We took the railing off and went through the window. You'll need to strip the motor down (pull oil pan etc). If you want to see pictures or have questions please feel free to email me. It's a job but very doable. Best of luck.
I've done that on a 36, just can't remember on the 39 why I think I've heard through the doors.
tonyiiiafl
Pretty much the answer I anticipated. Does not sound pretty or inexpen$ive. Thanks for the replies!
