1998 350 Mariner plotter change
- Wkuhilltopperfan
- Vessel Info: 1998. Mariner 350 . Twin 7.4 engines / kholer 6.5 gas Genset
- Has thanked: 17 times
- Been thanked: 18 times
Thank you
Re: 1998 350 Mariner plotter change
Also, a word of caution, if you replace the transducer you need at least 18hrs (I believe) if you use 4200 sealant, longer for 5200 before you can splash again.
- Wkuhilltopperfan
tomschauer wrote:Source of the post Unless you are looking for CHIRP, side scan etc, you can most likely get a raymarine depth finder / plotter that can use the existing transducer, may need an adapter cable.
I thought the tech department at raymarine had told me that the transducer was not compatible with any of the current products......I could be wrong , I would hope that I could other than the price that comes along with they're products
If you buy an expensive unit you may not want to risk warranty issues.
- waybomb
- CYO Moderator
- Been thanked: 490 times
