painting aft enclosures on 1988 carver aft cabin
Topic author
suncanoe
Vessel Info: 1988 carver aft cabin motor yacht. Twin 454 Mercruisers. Always fresh water.
Postby suncanoe » August 9th, 2013, 12:36 pm
We have a 1988 3806 Aft cabin that has enclosure around aft deck that needs to be painted. What type of paint would you use. Not sure what this material is. :help: :help: :help:
Been thanked: 490 times
Re: painting aft enclosures on 1988 carver aft cabin
Postby waybomb » August 9th, 2013, 6:32 pm
If fiberglass,use awlgrip. Never needs waxing, nor should you wax it. If you wax it, it yellows.
It's a two part epoxy system
It's what is used on hatteras and larger yachts
Topic author
suncanoe
Postby suncanoe » August 28th, 2013, 12:10 pm
Thanks for you response. I do think it is fiberglass. Where could I purchase this paint?
Postby waybomb » August 28th, 2013, 5:17 pm
Any marine supply store should have the ability to get out for you. Look up awkgrip and read up in it before you buy.
And there are different shades of white.
Ramsport47
Been thanked: 59 times
Postby Ramsport47 » August 30th, 2013, 6:39 am
A 1988 3807 Motor Yacht would have plexiglass weatherboards around the aft deck. I'm not sure what you could paint plexiglass with that would stick, although I know later that Carver used clear plex transom doors that they painted white, I assume with Awlgrip
Kenny
T-Merc 350 Mag MPI (300hp)
Postby waybomb » August 30th, 2013, 11:25 am
You are correct! I was thinking of our ex-4207, which was all fiberglass.
I am going to bet that Awlgrip will not work, but the best way to find out is contact them directly.
Maybe simply replace the smoked plastic with white plexiglass?
RichardS
Vessel Info: 1991 Carver 38 Aft Cabin
Postby RichardS » December 24th, 2013, 7:53 pm
waybomb wrote:You are correct! I was thinking of our ex-4207, which was all fiberglass.
If anybody is willing to trade their smoked plastic for my white plastic (near mint) I would be totally up for that! I was considering having the panels custom cut for me at a glass/plexi shop....a trade would be way better and a win-win for a guy who wants white!
Users browsing this forum: No registered users and 43 guests
