bow thruster in a 4207
glennmac
Vessel Info: carver 4207 aft cabin
Postby glennmac » December 6th, 2016, 11:24 pm
I am thinking of installing a bow thruster on my 1991 4207. has anybody done this? It looks like I might have to cut a hole in the floor of my forward cabin to get to an area where the motor and tunnel go. Is this doable, or will it weaken the hull in any way? Any thoughts or insights would be greatly appreciated
feeez
Vessel Info: 2001 350 Mariner
Has thanked: 52 times
Been thanked: 66 times
Re: bow thruster in a 4207
Postby feeez » December 8th, 2016, 11:44 pm
I have watched "several" videos of this. My conclusion is that unless you are really good with fiberglass and gelcoat refinishing hire a professional for the job!!!!
Cheers
Fraser
Former 2001 350 Mariner owner
Postby Viper » December 9th, 2016, 8:13 pm
glennmac wrote:Source of the post......I might have to cut a hole in the floor of my forward cabin to get to an area where the motor and tunnel go. Is this doable, or will it weaken the hull in any way?......
As long as you don't cut through a cross member that might be there bracing stringers, just cutting access in the floor for this application won't weaken the hull.
Are you doing the installation or having someone do it for you?
