Seawater impellar replacement Kohler
Tomion
Topic author - Deck Hand
- Vessel Info: Carver 530
- Has thanked: 1 time
- Been thanked: 2 times
I struggled for an hour trying to put new impellar in seawater pump today and then used a hose clamp to bend the blades around the hub enough to get started into pump housing. The keyway was still a bear to keep in place while inserting the impellar but some good light to line up impellar with key finally paid off. Have no idea how one would get impellar installed with pump on motor.
Re: Seawater impellar replacement Kohler
Found this which shows how easily it is done.
I can do it in a suit and tie that way
It's definitely a different experience trying to do it in the boat as I'm sure we're all aware, especially if you're working blind because you can't get in front of it to see what you're doing. Came close to removing some generators myself just for an impeller change. Oh the joy, the excitement of working on boats
Midnight Sun
- Vessel Info: 2007 Carver 41 CMY D6 370's
- Been thanked: 3 times
Tomion
Tomion
- ScubaPete
- Vessel Info: 2002 Carver 406
Cummins 6BTA 330's - Location: Seaford, Virginia
