CO detectors sounding alarm
- Has thanked: 314 times
- Been thanked: 583 times
Re: CO detectors sounding alarm
Also, as Viper mentioned, even with a diesel boat, I would have at least one CO detector, especially where you sleep. If you are rafted up or even at the marina a neighbor could gas you out.
- 405driver
- Vessel Info: 1998 Carver 405 gas
- Has thanked: 37 times
- Been thanked: 6 times
My 405 has five detectors, three brand new ones inside, one on the back deck and one upstairs by the helm. Maybe overkill but when it comes to CO I don't think you can be to careful.
- Has thanked: 550 times
- Been thanked: 1145 times
- 405driver
New detectors, new batteries and the charger is charging as described in Charles literature. The alarms are not the low voltage slow beep, if it were low voltage, why do the alarms stop when the cabin is ventilated?
I'm thinking of turning the alarms off unless either the engines or the generator running. I also think that I will put the air system in "humidity control" and see what happens.
Beats me....
- 405driver
As the old set of batteries had acid all over the top of them and in the bottom of the plastic case, I'm beginning to think that although the charger is running pretty close to the listed values in it's operations manual. that it's somehow frying the batteries.
Here's my latest clue that's its somehow the battery system. The sensor in the forward cabin has been consistently going off sometime during the night still sounding the alarm in the morning when I reach the boat. A few nights ago I reasoned that if I removed the floor hatch just in front of the forward cabin the H2 being lighter than air would escape through the hatch before reaching the forward cabin, therefore not setting off the alarm. The next morning, there was no alarm in the forward cabin. The gas went up through the hatch and never made to that part of the boat.....
You're right, the boat could be just very tight and the detector is just picking up H2 from charging. But, if it's the charger then it's going to fry a brand new set of batteries.....like the old set. The date on the old Deka battery was 2013 and it was seriously shot. Most high quality will last longer than three years.....but not if it's being over charged.
Last...my wife is getting suspicious as to where I'm going every morning......
- mjk1040
- Been thanked: 236 times
- Low Flyer
- Vessel Info: 1998 Carver 355 MY
Mercruiser Bluewater 454's - Location: Allatoona Marina Resort, Lake Allatoona, GA
- Has thanked: 2 times
- Been thanked: 7 times
Started having the same problem about six months ago and have not solved it yet.
Two year old number 1 battery was boiling and hot. I thought it was just low on water so I filled it and let it cool. Next day still hot and boiling so I removed it and replaced it. Then two year old number 2 battery was low on water but not hot so I filled it and left it in place. Three year old number 3 battery (Gen Battery) was slightly low filled it and left it in place.
The next day #2 battery was hot and boiling, #1 battery good and charging, #3 battery good and charging. Replaced #2 battery.
A week later #1 and #2 battery low on water, #3 battery normal. Filled batteries and left on the charger. A week later #1 and #2 battery low again. CO2 alarm going off. Replaced old Charles battery charger with brand new state of the art charger.
A week later #1 and #2 battery low on water, #3 battery normal. Replaced (free) #1 and #2 battery and bought new #3 battery. So now I have a brand new DC storage and charging system.
Two weeks later #1 and #2 battery low on water, #3 battery normal. CO2 alarm going off. Did the all to familiar battery maintenance and turned DC system off.
Two weeks later #1 and #2 batteries low but not as low. Started checking load on "always on" items (bilge pumps, shower pumps, radio memory, CO2 detectors) and found no load (pumps) or small normal loads.
Anyone have any ideas what else could be causing a load/amps that could be draining batteries so that the charger doesn't go into maintenance mode?
I emptied and turned off the refrigerator inside and at the breaker but the light inside still comes on. Doesn't the refrigerator automatically use AC power when it is available? So it should not be using battery power when shore power is connected.
Sorry this is so long but I too would like to find out what is messing up the brand new DC system. Any ideas?
1998 355 Aft Cabin
