Raw Water Impellers
- mjk1040
- Been thanked: 248 times
Raw Water Impellers
- Been thanked: 654 times
Re: Raw Water Impellers
- waybomb
- CYO Moderator
- Been thanked: 490 times
Even though these pumps have flexible fins, they are essentially a positive displacement pump.
- mjk1040
Waybomb-my thoughts exactly! However the Sherwood pump when new comes with 12 fin impeller. Now I have open cooling, so it may be possible more water is not a better idea. I have never seen the dash temp gauge go over 140 degrees, even though that may not be the exact temp of the engines. However as I stated above temp was not reading high or above 140, yet I would start to get steam coming out of the exhaust when the bad impeller was still in. After replacement at 140 I did not see any steam after running at idle as before.
- Been thanked: 1113 times
waybomb wrote:Source of the post Here's a thought - if there are less impellers, there will be more volume available for the water. Per revolution, less area taken up by the blades means more water moved.
Not necessarily. It's the displacement of the fins that moves the water. If you have 12 "displacements" per revolution you'd get more water pumped then if you only had 10 "displacements"... the rest of the water is just there for the ride.
Nice video of a pump running: https://www.youtube.com/watch?v=ECv1VwW6RTo
- waybomb
- CYO Moderator
If the cavity is 5 cubic inches, and the impeller takes up 1 cubic inch, each revolution will move 4 cubic inches of water.
Same cavity, impeller takes up 4 cubic inches, there is only enough room for 1 cubic inch of water to be moved.
waybomb wrote:Source of the post Beg to differ.
Don't think so!
By that logic, I could cut all the fins off my current impellers and improve my flow 500%!!
- waybomb
- CYO Moderator
For our applications, the number of blades is more about head pressures than volume. The more blades, the higher the head pressures the pump can deliver. The thinner the blades, the more they flex, this is desirable in some conditions as they are more forgiving but the pressures are reduced. The thicker blades offer higher pressures but are less flexible which is a drawback in some cases such as liquids that carry more debris.
To ensure you're pumping to pump design spec, find out what OEM impeller the pump manufacturer originally called for, then you can cross-reference to the same number of blades, thickness, etc., then stick to that if it works for you.
