Walter V-drive Question
Has thanked: 548 times
Been thanked: 1145 times
Re: Walter V-drive Question
Postby bud37 » June 17th, 2017, 10:23 am
amanphoto wrote:Source of the post I'm new to this and would like some clarification and info. I have a Walter direct mounted "V" drive. The oil has leaked out. My questions is where do I put more oil in? In the dipstick port? SAE-30 oil? Where should I look for a leak? Where are they prone to fail? Where do I change the oil out when it is time for maintenance?
Thanks for your help.
Because this happened to me.....maybe you have found the source by now , but if not...make sure your dipstick is locked in place properly, that will seal it to keep the fluid in the trans/transfer case when operating.....I know a little simple but worth a check.
The above is strictly my opinion always based on years of doing...remember to support local business , it pays back.
Has thanked: 432 times
Been thanked: 1587 times
Postby Viper » June 17th, 2017, 1:27 pm
I see now what you have. Ya SAE 30. Some guys are going with Merc HP gear oil. Look for leaking lines and fittings, input and output seal leaks.
Did they get run dry?
amanphoto
Has thanked: 3 times
Been thanked: 12 times
Postby amanphoto » June 18th, 2017, 1:20 pm
Do they sell rebuild kits for these?
Postby Viper » June 18th, 2017, 10:12 pm
Unless something has changed recently, they should still have kits available. Contact them http://www.waltergear.com/
