Boat will not plane
- waybomb
- CYO Moderator
- Vessel Info: 1987 3697 Carver Mariner
1969 15' Glaspar / 1969 Johnson Electrmatic 85
1964 Barron Flat bottom drag boat
A couple of dinghies - Location: Saint Joseph and Trenton, MI
- Has thanked: 41 times
- Been thanked: 313 times
Re: Boat will not plane
Disconnect the throttle linkage. Actuate the throttle quickly to wide open and let off just as quick, while intensely watching the vacuum gage. Does it go to zero vacuum? Did it get there smoothly? On the way back to idle, what exactly did the needle do?
What brand engines-Mercruiser, crusader, something else?
Did they time the engines? Are you comfortable with turning the distributor?
What ignition system do you have? Points? Do you have a dwell meter
and know how to use it, and adjust the points?
Vacuum gage can tell us all about the intake and exhaust cycles. W need to adjust the dwell if a points system, and then check timing.
1964 Barron Flatbottom with BBC Chevy
1969 Glaspar Avalon /1969 Johnson Electromatic 85
1988 Cougar Kevlar 46' with triple blown 572s
http://s4.beta.photobucket.com/user/waybomb/library/
- waybomb
- CYO Moderator
With the engines and everything turned off, not running.
Go to the bridge and open the throttle all the way.
Go down to the carburetors.
Pull the flame arrestors off.
Manually open the choke and secondary air butterflies
Look down the carburetor - the throttle butterflies should be perfectly vertical.
If not, find the linkage adjusters on the throttle cables at the carburetor, and adjust until the butterflies are 100% open.
Then go to the bridge, close the throttles, go back down and make sure the throttle butterflies are closed, and the carburetor's throttle linkage is up against its stop.
If the throttles were not all the way open and you had to adjust, go take it out for a ride and see how it performs.
Topic author - Scurvy Dog
- Vessel Info: 1979 33' carver
New Orleans, LA
- Ramsport47
- Has thanked: 72 times
- Been thanked: 53 times
T-Merc 350 Mag MPI (300hp)
- Seif911
- Captain
- Vessel Info: 1977 Carver Mariner 33'
- Been thanked: 3 times
Good luck and keep us up to date.
Steve
New Orleans, LA
- waybomb
- CYO Moderator
Idel vac is good and you throttle blip indicates a genreally good engine.
Need to find out what the noise is.
Does it seem to be under a valve cover? If so, pull that valve cover and look for a rocker arm when the cam is on the baseline. May be a bad lifter or someting with the rocker / pushrod / valve. Don;t go too long with this condition!
Users browsing this forum: No registered users and 7 guests
