TV Reception/Antenna Issue
Blue
Topic author - Scurvy Dog
- Vessel Info: 2006 Carver 36 Mariner
Blue
Re: TV Reception/Antenna Issue
- waybomb
- CYO Moderator
- Been thanked: 490 times
If you can find that box, then you can check if power is connected to it.
The power enables circuitry to amplify whatever signal is available.
Sat or cable will work with any tv, so you should not have toe worry about that.
I would hook up a dvd player and rent shows if I had free time to kill on the boat.
Blue
- Luv'n Life
- Vessel Info: 1999 Carver 380 Santego SE
After Taxes
- Vessel Info: 'After Taxes'
2004 Carver Mariner 360
Lake Simcoe & Georgian Bay,
Ontario, Canada - Location: Lake Simcoe Marina
- Has thanked: 6 times
- Been thanked: 17 times
BTW, can you post your solution to your original inquiry? Thanks.
MerCruiser MX 6.2
Lake Simcoe, Ontario
