Location of reversing solenoid
hlhall
Vessel Info: 1998 Carver 445 Aft Cabin (Gas)
Postby hlhall » August 14th, 2017, 3:01 pm
Hi all, 1998 Carver 445 AC with a Maxwell Freedom 800 winch that is starting to misbehave. One of the manual's troubleshooting tips is to test the reversing solenoid, but it also says that during install, the solenoid is not supposed to be installed in the chain locker. Any idea where this might be found? Would they have put it in the helm station (where the remote panel is) or is it probably in the chain locker?
Thanks in advance!
Re: Location of reversing solenoid
Postby Viper » August 15th, 2017, 12:32 am
Did you check the chain locker? It's not ideal but I've seen a lot of them installed there.
hlhall
Postby hlhall » August 28th, 2017, 6:15 am
It is indeed in the chain locker, right where the manual says you are not supposed to put it.
However, I found the underlying problem with the winch -- my battery was starting to fail and was apparently not putting out sufficient amos to drive the winch. Switched to battery 2 and the winch works just fine. Ordered two new batteries, so once I manage to wrestle 2 127 lb batteries out and get the two new ones in, I should be good to go.
Users browsing this forum: KyleR and 22 guests
