32 Carver aft cabin Carburetors
- MakinTime
- Vessel Info: Carver 3607 MakinTIme
Glastron MX175 MakinTimeToo - Has thanked: 52 times
- Been thanked: 31 times
- MakinTime
Re: 32 Carver aft cabin Carburetors
- Has thanked: 598 times
- Been thanked: 1281 times
- waybomb
- CYO Moderator
- Has thanked: 64 times
- Been thanked: 481 times
What's the concern?
- mjk1040
- Been thanked: 246 times
- MakinTime
- Been thanked: 601 times
Get a couple $20 rebuild kits and replace the bow gaskets and the float level gaskets. Set the fuel level correctly in the bowls and you should be good to go.
If you replace all the gaskets and set the levels correctly so they are not dumping fuel into the manifold, your smell should go away.
- Has thanked: 78 times
- Been thanked: 1093 times
I would also check the fuel pump feed to the carb to make sure you're not seeing any fuel there... that's an indication of a pump diaphram failure.
If you're seeing gas at the top of the carb, it's probably either a mis-adjusted float, a bad float, or a dirty needle/seat. Very easy items to troubleshoot and fix.
- Has thanked: 468 times
- Been thanked: 1765 times
Did it smell like gas before he bought the boat, when he first viewed it?
Have you checked the fuel fill hoses to the tanks and the tank vent hoses for cracks?
Have you checked the base of the tanks for signs of leaks?
What year is the boat?
Were the tanks pressure tested?
Did he get a survey?
- MakinTime
