1991 2557
up4air
Topic author - Scurvy Dog
- Vessel Info: 1991 Montego 528 (2557)
- Has thanked: 2 times
1991 2557
I've discovered I've got a leak on the pressure side of my fresh water and if leaving on the power to the pump, my tank will pump dry into my bilge so got to track that down. It could be the water heater tank un in the bow but will look into further when the weather warms up. I did find, please look at pictures, under the cover in the aft cabin this conglomeration of vales and pumps. Anyone know wth these are?
Thanks so much for any info
- Has thanked: 602 times
- Been thanked: 1311 times
Re: 1991 2557
- Been thanked: 1113 times
Re: 1991 2557
That screen is probably either on the input of the potable water pump (should have one there to protect the pump from debris) or it could be connected to that thru-hull and goes to feed the water input to the head. You need to trace the hoses to find out.
Doesn't look like there is a fuse in the line that feeds the potable water pump, but there should be one there somewhere. It might just be out of the picture. The circuit breaker protects the wire, but there should be an appropriately-sized fuse just before the pump to prevent a locked-rotor from damaging the pump.
That grey plastic water tubing is notorious for cracking at the fittings and developing leaks. Put in the plan someday to replace it all with PEX, and you'll really appreciate it. I dealt with the leaks on the grey stuff for years before I finally fixed it ALL with a couple-days project to redo it all in PEX.
