AFT DECK SHOWER BOX
DistinctivelyLost
Vessel Info: 1995 Carver 430 CMY
AFT DECK SHOWER BOX
Postby DistinctivelyLost » March 29th, 2018, 7:44 pm
Hey Everyone,
I'm trying to replace the shower box on a 430 Carver CMY. I'm having trouble sourcing a box of the same dimensions. I've attached a picture of the current box. The outside dimensions are 10 1/4 x 7 5/8. The ID I'd estimate at 8 3/4 x 6.
Some Einstein 5200'd the thing in at some point (not me) so I want to make sure I source a suitable replacement before I start chiseling the thing out.
The ID is important, but, because of where it's mounted on the transom the OD is important too. I can always increase the ID, but, not the OD dimension due to how it approaches the top of the transom bulwark.
Any sources or ideas are appreciated.
-Matt
1995 Carver 430 CMY
Re: AFT DECK SHOWER BOX
Postby mjk1040 » March 29th, 2018, 7:53 pm
Try emailing or call Carver with your haul number. They may be able to point you in the right direction. Everything I see is rectangle not square! You may be able to save the box and change out the components from a similar unit.
Postby Viper » March 29th, 2018, 10:16 pm
Welcome aboard Matt.
That's an SSI fixture. I come up with # 48600000. It may be discontinued but you might find a retailer that still has stock. I'm pretty sure Defender and West Marine carry SSI or try contacting SSI.
https://ssicustomplastics.com/
PhilH
Vessel Info: Carver Californian 45 M/Y, 1990 Cat 3208 diesels
Has thanked: 5 times
Been thanked: 3 times
Postby PhilH » April 21st, 2018, 1:55 am
Boat owners Warehouse has a SSI unit 12 1/4 wide by 7 1/4 h x 3 1/2deep, but the cutout is 10 3/4 x 5 3/4. Maybe? Part 200331. $120.00
Users browsing this forum: Rocketman and 33 guests
