2001 Carver 444 AC
Tomion
Topic author - Deck Hand
- Vessel Info: Carver 530
- Has thanked: 1 time
- Been thanked: 2 times
2001 Carver 444 AC
The AC units will not show anything on thermostat control units when power is selected. It appears as though they have no power to them. It has to be something in the power supply as all units are independent except for the water pump system?
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: 2001 Carver 444 AC
On your electric panel...do you have voltage and amp meters and are they showing voltage coming in?
What kind of power do you have? 2 x 30 amp or 1 x 50 amp?
If you have 2 x 30, Try swapping power cords at the dock to see what happens. Maybe you have a bad dock circuit.
Dumb question...are all three circuit breakers in the on position?
- buster53
Tomion
I has to be a power issue but I cant figure it out. If I had an input power issue why would I have 120 showing on bith lines. I dont have a main CB just 4 breaker / switches that are all on.
- Been thanked: 1113 times
As Viper suggests, try it with the generator on. There are relays that get flipped with the generator on and they may have bad contact on the shore power side.
Tomion
- Has thanked: 603 times
- Been thanked: 1311 times
Do you have the manual for this boat ?..
Tomion
Tomion
