Fresh water pump ok if under water?
- CptBacardi
- Vessel Info: 1989 Carver 38 Santego (not an aft cabin)
- Has thanked: 3 times
Re: Fresh water pump ok if under water?
I don't think any of those pumps are designed to be submersible, so I would not expect that pressure switch to be sealed. If the connections themselves will be underwater, they should be sealed with shrink boot.
You may connect it back up and have it work for a while, but I think you may need to at least replace that pressure switch at some point.
- CptBacardi
1990 Proline 17CC
2018 Regal 1900ESX - Location: upper chesapeake bay
- Has thanked: 85 times
- Been thanked: 229 times
Users browsing this forum: No registered users and 5 guests
