WOT less than 3k
tonyiiiafl
Has thanked: 34 times
Been thanked: 20 times
Re: WOT less than 3k
Postby tonyiiiafl » September 15th, 2018, 6:19 am
I had that issue, and it turned out be a soft camshaft, lobes were worn.
Vessel Info: 1987 3697 Carver Mariner
1969 15' Glaspar / 1969 Johnson Electrmatic 85
1964 Barron Flat bottom drag boat
A couple of dinghies
Has thanked: 30 times
Been thanked: 200 times
Postby waybomb » September 15th, 2018, 6:32 pm
Hook up a vacuum gage to manifold vacuum.
Tell me what the needle is doing at idle, and the level of vacuum at idle.
1964 Barron Flatbottom with BBC Chevy
1988 Cougar Kevlar 46' with triple blown 572s
http://s4.beta.photobucket.com/user/waybomb/library/
Capn Crunch
Vessel Info: 1989 Carver Montego 2557
Location: On the Mighty Columbia River in the Pacific Northwest
Has thanked: 36 times
Been thanked: 7 times
Postby Capn Crunch » September 15th, 2018, 8:23 pm
waybomb wrote:Source of the post Hook up a vacuum gage to manifold vacuum.
I can't until Tuesday, Mechanic has Quadra-Jet pulled, in a tank soaking and destined for a rebuild kit Monday... reinstalling Tuesday.
Capn Crunch
Postby Capn Crunch » September 15th, 2018, 8:24 pm
tonyiiiafl wrote:Source of the post I had that issue, and it turned out be a soft camshaft, lobes were worn.
Man I hope that's not contagious...
Capn Crunch
Postby Capn Crunch » September 19th, 2018, 4:55 pm
Update 2018-09-19:
Mechanic brought his mentor... proceeded with re-checking timing, this time @ idle and @ 3k to prove advance working - check!
Mentor then pulled each plug wire one at a time while running and found #4 not getting spark. We never found a break in the wire but after disconnecting and reconnecting wires and pulling left bank off the wire holder mounted on block the motor sounded like a race engine compared to previously. We then sea trialed her - hit 4100 right away, he trimmed motor out to see 4500rpm... and hit 29 mph!!! Woot Woot!!
Thanks all for your suggestions... extremely happy that it turned out to be something minor... and got new electronic advance, carb rebuild and fresh tune-up gratis to boot!!
Mark
AaHubb
Vessel Info: '99 404 CPMY
my twin diesel pusher
Has thanked: 8 times
Been thanked: 38 times
Postby AaHubb » September 20th, 2018, 10:24 am
Hey that's great news Mark. See ya on the river. :-)
..Aaron
'99 404 CPMY
SeaDragon
Capn Crunch
Postby Capn Crunch » September 20th, 2018, 1:06 pm
Well now I guess my ignorance is going to shine once again... went to buy new plug wires this morning only to be told there's 12 or more different versions of wires... person then made her best guess and pulled out wires that were labeled exclusively for EFI systems.
So my question is just how much different would wires be across all the different versions of a Mercruiser Thunderbolt 5.7L carbed engine?
Ok, 2 questions... where do you all go online to get parts like this?
Thanks again to all for keeping me on the straight and narrow...
Mark
Has thanked: 247 times
Been thanked: 381 times
Postby bud37 » September 20th, 2018, 1:19 pm
Heh Mark....try Mercury website and there is a parts drop down where you can choose your engine type and serial number range etc and then pick thru what parts you want and get the numbers ....that is what I do, at least that way you will be armed with some info when you go to get the parts.
Capn Crunch
Postby Capn Crunch » September 20th, 2018, 1:42 pm
bud37 wrote:Source of the post Heh Mark....try Mercury website and there is a parts drop down where you can choose your engine type and serial number range etc and then pick thru what parts you want and get the numbers ....that is what I do, at least that way you will be armed with some info when you go to get the parts.
Thanks bud37... after arming yourself do you shop online or locally for tune-up parts? If online, where do you normally shop?
1990 Proline 17CC
2018 Regal 1900ESX
Has thanked: 85 times
Been thanked: 229 times
Postby tomschauer » September 20th, 2018, 1:48 pm
Mark, as Bud says, take your year and serial number to the mercury parts look up.
Wires can have different ends for standard ignition / newer electronic ignition, also the plug boots may be straight or 90 degrees and the wire sets will be different lengths for different applications.
I usually shop online, as no one near me stocks the marine part numbers even after x ref.
Users browsing this forum: No registered users and 2 guests
