370 Voyager 1993 Propellers
Topic author Great Britain
Tim Sperryn
Vessel Info: Carver 370 Voyager 1992/ 1993 model
Postby Tim Sperryn » September 14th, 2018, 7:11 am
Hi
I'm seeking prop specs for the above boat with Cummins 300's?
ps: great to be part of CYO!
Has thanked: 271 times
Been thanked: 421 times
Re: 370 Voyager 1993 Propellers
Postby bud37 » September 14th, 2018, 8:40 am
Welcome to the forum.....is the boat new to you ?.....sometimes original prop specs from the factory sea trials could be misleading, especially for older boats that have thousands of pounds more stuff on board.
My guess , e mail Carver with your hull number and engine numbers and they may have the original specs for you.Also maybe someone here with the same combo can help......good luck man...
Vessel Info: 1989 Carver 3807
Has thanked: 129 times
Been thanked: 571 times
Postby Viper » September 14th, 2018, 10:13 am
Welcome aboard. Hopefully a nother member with the vessel will chime in.
Vessel Info: 1987 3697 Carver Mariner
1969 15' Glaspar / 1969 Johnson Electrmatic 85
1964 Barron Flat bottom drag boat
A couple of dinghies
Has thanked: 33 times
Been thanked: 220 times
Postby waybomb » September 14th, 2018, 11:56 am
Welcome aboard!
1964 Barron Flatbottom with BBC Chevy
1988 Cougar Kevlar 46' with triple blown 572s
http://s4.beta.photobucket.com/user/waybomb/library/
Vessel Info: 1981 Carver 3007 Aft Cabin
Has thanked: 43 times
Been thanked: 230 times
Postby RGrew176 » September 15th, 2018, 12:10 am
Welcome aboard. Good luck in your propeller search. Good news is someone here will have an answer to your question.
www.wrycc.com
Users browsing this forum: No registered users and 6 guests
