Carver 506 A/C Water pump replacement
jfloyd1010
Vessel Info: 2001 Carver 506 "Endless Journey" 450 hp Cummins 6CTA 8.3-M engines
Been thanked: 2 times
Postby jfloyd1010 » December 6th, 2018, 12:39 pm
Hi all,
I've had a main water pump go down that supplies water for 4 A/C units on my boat.
I found a replacement at Grainger for the Dayton 9MWR7 motor portion of the pump assy but now I need to find a new impeller and shaft seals for the pump portion. There is no OEM info on the pump castings.
Has anyone had to replace these yet on their boat ?
Thanks !
Jim
1990 Proline 17CC
2018 Regal 1900ESX
Has thanked: 181 times
Been thanked: 373 times
Re: Carver 506 A/C Water pump replacement
Postby tomschauer » December 6th, 2018, 1:04 pm
Does it not have a shurflo or jabsco model number on the original pump motor? That would tell you the flow rate and pressure. Unfortunately, it is most likely cheaper to buy a complete new pump than replace the motor and internals on your existing pump.
Has thanked: 335 times
Been thanked: 589 times
Postby bud37 » December 6th, 2018, 1:52 pm
tomschauer wrote:Source of the post Does it not have a shurflo or jabsco model number on the original pump motor? That would tell you the flow rate and pressure. Unfortunately, it is most likely cheaper to buy a complete new pump than replace the motor and internals on your existing pump.
+1
Good idea to replace the entire assembly, then maybe rebuild the old one over time to keep as a spare...... :beergood:
"There is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.”
― Kenneth Grahame, The Wind in the Willows
Safe travels with light winds and calm seas.....
jfloyd1010
Postby jfloyd1010 » December 6th, 2018, 1:56 pm
Here is a picture of the Dayton pump motor ID label
1990 Proline 17CC
2018 Regal 1900ESX
Postby tomschauer » December 6th, 2018, 3:05 pm
If you cant find the flow info on the pump anywhere, see if you can determine the flow rate required for each a/c unit then add them together.
jfloyd1010
Postby jfloyd1010 » December 6th, 2018, 3:40 pm
After about 6 phone calls and even more web searches, I was finally forwarded to Depco Pump who verified via my pictures what I had and sent me the below information.
"What you have is an Oberdorfer 109MB. There is a lot of cavitation on the pump body (internal) and parts itself. Buying just a service kit is not worth it, too much deterioration.
If the motor still good you can buy the complete pump head which is 109MB $566.20 (comes with everything) in stock.
Pump and motor assembly you have two choices:
109MB-J19 CENT PUMP with 1/2HP 115/230V 60Hz $928.36 in stock (If you don’t need 50Hz, this is what I recommend)
109MB-10J36BJ-50/60 1/2HP 115/230V / 50-60Hz /316SS motor shaft $1129.00 in stock. (your current motor is 50/60 Hz)
If you have any further questions, please let me know.
Best regards,
Dorian Latorre | Marine Sales
dorianl@depcopump.com
727-446-1656 MAIN
727-446-7867 FAX
800-446-1656 TOLL FREE
Hope this info helps someone else down the road.
Jim
Vessel Info: 1981 Carver 3007 Aft Cabin
Has thanked: 48 times
Been thanked: 316 times
Postby RGrew176 » December 7th, 2018, 3:33 am
Wow, that is one pricey pump. I had to replace mine 2 years ago. I paid about $350 for a 500 (490 actual) GPH pump. Then again I am only powering one 16000 BTU unit not 4 like you.
www.wrycc.com
Has thanked: 123 times
Been thanked: 483 times
Postby Midnightsun » December 7th, 2018, 5:14 am
Here is a link to a better deal. https://pumpsforless.com/product/oberdo ... 109mb-j19/
Is this the original pump? Reason I ask is the darn thing produces 3600 gph which is a lot of flow. A standard 16,000 btu unit needs around 400gph or 1600 gph for 4 units x 16,000 btu units which I doubt you have. You could direct the flow to be used as a truster though. :-D
Here are the complete specs on the unit. https://www.google.com/url?sa=t&rct=j&q ... EbQCbNZfCm
Postby bud37 » December 7th, 2018, 9:44 am
The pump flow numbers may be given as a maximum, that would be no head pressure.....so in a system with head pressure you would have to see the flow curve charts. I don't believe it is a linear calculation, that could be the reason for the apparent oversize. Centrifugal pumps are sized differently that postitive displacement.
jfloyd1010
Postby jfloyd1010 » December 10th, 2018, 1:37 pm
Thanks Hans !
Users browsing this forum: No registered users and 0 guests
