Antifreeze or just drain?
- VicB
- Vessel Info: 1988 Carver 3807
- Has thanked: 41 times
- Been thanked: 11 times
- Has thanked: 603 times
- Been thanked: 1311 times
Re: Antifreeze or just drain?
Watch a couple videos on winterizing , there are some where they pour AF in the top after draining if that would make you more comfortable. There are probably many ways of doing this that work, I am sure others will have their versions. Good luck man , don't sweat it.
darrenlife
- Vessel Info: 2002 Carver 410 Sport Sedan
- Been thanked: 36 times
https://www.defender.com/product.jsp?pa ... id=2755962
I ended up installing them part way between my seacocks and water pump in a place that was easiest to access.
Do you have the option of removing the hose connected to the inlet side of your water pump and connecting a section of equal diameter hose to coo etc to your jug of pink? This may be alternative to removing hose from seacock.
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
I didn't think Crusader ever made raw water cooled engines.
Is the boat in the water or out? Big difference. In the water you have nothing to worry about. Out of the water and if you have a bad cold snap, you have reason to worry.
In the spring when you fire up your engines for the first time and see what comes out of your exhaust, you will never leave raw water (or no water) in them again. Just have someone fire up the engines while you watch the exhaust. It will make you sick.
- VicB
Here is my port engine It’s definitely raw water cooled. I was surprised they didn’t have strainers when I bought it. I’m thinking about pulling the thermostat cover and just pouring antifreeze in both directions from there. Like I said, I am unsure about leaving the block and exhaust dry but if I fill it and we get some pretty days it would be great to take the boat from a spin. Again most on the dock do absolutely nothing. They don’t even seem to visit their boat. Still have paddle boards and lawn chairs on them like they haven’t been there since summer.
- mjk1040
- Been thanked: 248 times
Users browsing this forum: Carverlvr2 and 26 guests
