Merc Smartcraft Gateway
- Sadey
- Vessel Info: Former owner of a 2003 Carver 356 with 8.1 Mercs
Agradecida
Benedetto - Location: Racine Wisconsin/Ft. Lauderdale
- Has thanked: 4 times
- Been thanked: 29 times
Dave & Trina
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
Re: Merc Smartcraft Gateway
In the case of Volvo you need the electronic brain so to say which computes and sends the info equivalent to Smartcraft called EVC otherwise this conversion is not possible just like having an older Mercruiser without Smartcraft. Bottom line is you must have factory installed Smartcraft or EVC to make this happen.
- Sadey
Agradecida
Dave & Trina
If you have anything Smartcraft on your gauges at the bridge then it is already at the bridge which makes life so much easier. If nothing is at the Bridge you obviously need to look at wiring from engine up to bridge.
- Sadey
Agradecida
Dave & Trina
darrenlife
- Vessel Info: 2002 Carver 410 Sport Sedan
- Been thanked: 36 times
Previous owner ran smartcraft cabling from engine to helm that had connect to a Navman which is no longer in place. To the best of my knowledge, I don’t believe I have a N2K backbone on the boat that I have found and curious if anyone has been down this road and what I might need?
What are people’s experience in getting help from Mercury?
[image][
/image][image][
/image]- bud37
- Has thanked: 602 times
- Been thanked: 1311 times
https://support.garmin.com/en-CA/?faq=k ... CyoDZIThd7
- Sadey
Agradecida
Dave & Trina
darrenlife
Thanks Sadey and Bud37. Currently not connected to anything, It used to be connected to a Navman unit that ‘two owners go’ took with them and the cabling has been sitting idle ever since. I’ll try sending pictures to Garmin and see how far I get.
