Volvo QS BP1200 bow thruster replacement
- Has thanked: 432 times
- Been thanked: 1588 times
Re: Volvo QS BP1200 bow thruster replacement
I started thinking about all the sources of how petroleum products make their way into the waterways on boats. Taking measures to eliminate as much of that as possible is a good thing whether at the manufacturing or ownership level. Techs can make a huge difference here too. Don't know how many times I see techs greasing all the points on a sterndrive and not even bother to clean the excess grease off the grease nipple. Marinas can play a huge roll too. All too often I see marinas launching boats where the trim tab actuators are clearly leaking, that should be an automatic no launch until it's fixed. It may seem like a small amount but add that up for all the sterndrives, trim tab actuators, etc. out there...it all adds up. Sterndrives are the worst, there's so much grease in the water with them. Heaven forbid you have a bad enough impact to break the lower unit and spill it's entire contents of gear lube. You know, they push marinas to use vegetable based oils and greases for their equipment working around the water but there's nothing said about what gets used in vessel hardware actually running and sitting in water all the time. Having said that, I think it's just a matter of time before that changes.
- dtlag
- Vessel Info: 1999 Carver 406 Aft Cabin Motor Yacht
- Has thanked: 2 times
Just wanted to check to see if anyone had found a good source for parts for these or a suitable replacement?
Thank you!!
- Royb
- Vessel Info: Carver 530 Voyager
- Been thanked: 5 times
- Royb
- eburklo
- Vessel Info: 2003 Carver 564
- Joemo4454
- Vessel Info: Marine/ bow thruster tech
- andbro
- Vessel Info: I have a Colin Archer 47 traditional sailing rescue vessel. I know this is ver far from a Carver, but found a thread discussing Volvo’s QL BP1200 and how to source parts for the gearbox. Esp a post by Royb in Dec 2021 with pictures showing part numbers for bearings and gears would be very valuable. Also would to ask the members is someone know if the gears can be bought off the shelf from manufacturer and if someone knows the angles with which the gears meet inside the gearbox.
- Has thanked: 1 time
and thank you for a lot of very valuable information about the BP1200. Esp. thank you to Royb for posting the info and picture with the bearings - super valuable!
One thing which remains for me to repair my thruster is the broken gears - the teeth are all basically sheared off.
Does anyone know if these were standard off the shelf as well or if not, does anyone have the design specs or can measure the outer height of the teeth and the angle of the upper outer corner of the teeth towards the centre? Knowing this it would be possible to source gears off the shelf or worst case manufacture new ones. Would be happy to place an order for several if anyone is interested.
Users browsing this forum: No registered users and 44 guests
