Replacing VHF antenna, uses RG5 cable?
- Mary-Bill
- Vessel Info: 2008 Carver Mariner 36
- Been thanked: 1111 times
Re: Replacing VHF antenna, uses RG5 cable?
Your bigger concern is putting a splice near the antenna. While it "CAN" be done, doing it so it's virtually transparent to the transmitter is the bigger issue. If there's any reflection in the signal it will reduce your effective transmitting power. If the cable provided with the antenna is long enough to make the run in one piece, then I'd suffer through fishing the new wire from one end to the other.
Also, having an extra connection in the system introduces yet another point of failure that you'd rather avoid.
- Has thanked: 602 times
- Been thanked: 1310 times
On ours there is access behind the panels on the arch base......not sure of your model though.
Users browsing this forum: No registered users and 100 guests
