dual station switch issues
- Johnnymalibu
- Vessel Info: 1984 Carver Santa Cruz
Thank you for any help
Re: dual station switch issues
- Been thanked: 1113 times
- Johnnymalibu
Midnightsun wrote:Source of the post how does this switch work at he fly bridge? Do you hold it in and then turn the key simultaneously and then release once started? Is there a key?
yes you push it in to start then release it .
yes we have a key
- Johnnymalibu
km1125 wrote:Source of the post I wonder if you HAVE to push that switch in or if it was just a "combining" switch so he would start on both batteries? He may have had to do it sometimes if one of the batteries was weak or old, or may have just preferred to do it that way.
It has a battery switch you have to turn manual from battery one to two .
Johnnymalibu wrote:Source of the postMidnightsun wrote:Source of the post how does this switch work at he fly bridge? Do you hold it in and then turn the key simultaneously and then release once started? Is there a key?
yes we have a key
Need more info. Do you turn the key to on then push the button until it starts and then release the button once started? To turn off do you simply turn off the key?
Midnightsun wrote:Source of the postJohnnymalibu wrote:Source of the postMidnightsun wrote:Source of the post how does this switch work at he fly bridge? Do you hold it in and then turn the key simultaneously and then release once started? Is there a key?
yes we have a key
And what happens at the lower station... does it have a key also?
- Johnnymalibu
yes we have a key
you push and hold then turn the key to start it and then release the button once it starts
- Johnnymalibu
Users browsing this forum: Google [Bot] and 16 guests
