Engine Compartment Sealant
- Marty
- Vessel Info: 2000 326 AFT Cabin
- Has thanked: 16 times
- Been thanked: 9 times
Thanks in advance
- Has thanked: 597 times
- Been thanked: 1281 times
Re: Engine Compartment Sealant
- Marty
- Been thanked: 601 times
For the holes, if they are subject to water use 3m 4200 or 5200. You can actually use the 3m for the insulation panels also, but you will need to keep pressure on the panels a lot longer and the 3m is much more $$.
- Been thanked: 1180 times
If the foam panels are on a wooden bulkhead or any thick wood, lets say floor hatches,( not the hull )...
..... I have used a few plastic cap nails to hold in place with the glue if you have the real heavy foam with the sound deadener layer inside.Return to “General Repairs & Maintenance”
Users browsing this forum: No registered users and 47 guests
