Engine Compartment Sealant
Marty
Vessel Info: 2000 326 AFT Cabin
Has thanked: 15 times
Been thanked: 6 times
Postby Marty » May 15th, 2019, 11:14 am
Any recommendations as to what to use to reseal a couple panels and small holes?
Thanks in advance
Has thanked: 335 times
Been thanked: 590 times
Re: Engine Compartment Sealant
Postby bud37 » May 15th, 2019, 6:33 pm
Heh Marty , can you elaborate a bit as to what material these panels and holes are etc.....
"There is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.”
― Kenneth Grahame, The Wind in the Willows
Safe travels with light winds and calm seas.....
Marty
Postby Marty » May 16th, 2019, 6:27 am
Couple fire panels came loose (ones with silver coating) and I want to run a couple 14ga wires to power a DC socket.
1990 Proline 17CC
2018 Regal 1900ESX
Has thanked: 181 times
Been thanked: 374 times
Postby tomschauer » May 17th, 2019, 1:04 am
For the insulation panels you can use any good adhesive, such as power grab etc.
For the holes, if they are subject to water use 3m 4200 or 5200. You can actually use the 3m for the insulation panels also, but you will need to keep pressure on the panels a lot longer and the 3m is much more $$.
Has thanked: 123 times
Been thanked: 483 times
Postby Midnightsun » May 17th, 2019, 5:17 am
It sounds like you are talking about the sound insulation panels which consist mostly of foam rubber and foil. That being the case, any spray adhesive (3m Super 77 is a good one) or contact cement will work well if the panel has come loose in some areas. As for holes they really do not matter all that much but if they bother you then I would use aluminum tape (type used on ducts) to patch up any tears or holes.
Postby bud37 » May 17th, 2019, 6:09 am
+1 on the 3m 77 for the foam.....never hurts to say..... ventilate well after using anything that has flammable fumes in an engine compartment or any enclosed area for that matter.
If the foam panels are on a wooden bulkhead or any thick wood, lets say floor hatches,( not the hull )... :-O ..... I have used a few plastic cap nails to hold in place with the glue if you have the real heavy foam with the sound deadener layer inside.
Users browsing this forum: No registered users and 7 guests
