ecu losing voltage
- Mike Dieterle
- Vessel Info: 1996 320 voyager with twin 350 crusaders
- Has thanked: 11 times
ecu losing voltage
- Been thanked: 1113 times
Re: ecu losing voltage
The ignition switch as mentioned is a good one. Check the oil pressure switch, if it is faulty or intermittent, the fuel pump won't run properly or at all. This is a safety feature. So I assume you have confirmed that indeed the fuel pump looses power?
You have the benefit of two engines, I recommend you stop throwing new parts at it unless you know for sure they are faulty otherwise you could be spending a fortune replacing perfectly good parts. If you suspect a part, swap it to the other engine and see if the fault follows the part. Swap only one part at a time so you know which part is causing the problem.
Post your engine's model number so we can look up some diagrams.
- Mike Dieterle
not to sound rude or dis respectful in any way but are sure about the oil psi sending unit being tied to the fuel pump as a fail safe and if so I will buy one of them due to it be not that expensive anyways.
I am with you on this as it does unusual however coming from Viper I would take this as fact.
- Has thanked: 603 times
- Been thanked: 1311 times
To add, anything with an electric fuel pump will or should have a safety shut-off in case the engine fails, you don't want the fuel still pumping.
- Mike Dieterle
bud37 wrote:Source of the post There is one other part I would inspect very, very closely....the engine harness connector plug.......
+1
