Cable gauge size for 20' run
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
9" RAY e97
12" Ray e127
Quantum 2 Dome
Raystar 130 GPS
Evolution Auto Pilot
What sized cable would you suggest? Would a number 4 be sufficient? Or should I go to a #2?
Thanks!
Re: Cable gauge size for 20' run
- tonyiiiafl
- tonyiiiafl
- Has thanked: 602 times
- Been thanked: 1311 times
- tonyiiiafl
tonyiiiafl wrote:Source of the post Would you ground to the engine block
Yes..
Ultimately the best way is to put a ground bus in the engine compartment and run the grounds to it , then just one ground from each of the battery banks and the engines to the bus. Then you can use that bus as a connecting point for the bus at the bridge etc. Just a cleaner way of doing it, makes for good connections.
- tonyiiiafl
I can ground there and then run to the fly bridge?
That's what I would do.
