406 - travel lift or trailer haul out
- nmcap
- Vessel Info: 1999 Carver 406 aft cabin motor yacht
twin 454 crusaders
I was always taken out of the water with a travel lift then moved to a spot in the yard (while still in the slings) and then put on blocks.
Now I have a new yard and they want to take me out of the water with a travel lift, then the lift
puts the boat on a trailer and the trailer moves the boat into its spot in the yard - like 1000ft over a paved yard.
Now I am worried about it being moved on a trailer - is it safe to move the boat on a trailer?
- Craig_B
- Vessel Info: 1988 Carver Santego 3067
- Has thanked: 144 times
- Been thanked: 13 times
Re: 406 - travel lift or trailer haul out
https://www.flickr.com/photos/giarc_dranrab/albums/72157707558217844
The rest of our picture albums.
- Been thanked: 1113 times
Don't think it would be any issue as long as they support the boat properly.
With the hydraulic trailers they have now, they could nearly set the boat on the ground. It's blocked up, but not very high. They used to use flatbed trailers and beams, and the boat waterline would be about 4-5' off the ground. Made it tough to wheel out the hullsides, as everything you did had to be at the top of a ladder!'
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
Krates Marina in Keswick is one of the largest marinas in Ontario and they remove all of their boats by a travel lift and transfer them to a trailer to be taken to different areas in their yard.
Clearly your folks need to have the right trailer and know what they are doing. All is good with this process from my experience.
Greg
- Has thanked: 603 times
- Been thanked: 1311 times
nmcap wrote:Source of the post Now I have a new yard and they want to take me out of the water with a travel lift, then the lift
You will be fine......I came out today...travel lift to trailer then over to its spot....the boat behind me was over 50 and 54000 lbs....same thing, travel lift to trailer.....now there are different size trailers but they will know....
- nmcap
twin 454 crusaders
with the deep V.
Does anyone have a 406 that comes out on a trailer?
Thanks for all your help
- golgi
- Vessel Info: Carver 530 Voyager Pilothouse
- Has thanked: 19 times
- Been thanked: 6 times
golgi wrote:Source of the post Mine isn't the same model as yours, but my yard told me never to have my 530 pulled by trailer. There's something to do with the engine stringers as a weak point. They pulled a 570 by trailer at the owner's request (didn't want to wait for travel lift availability) and basically had the motors drop out the bottom. Something to consider besides just weight and hull shape.
I agree completely.....have seen an over 50' boat in a travel lift with only two single slings and they were ok with it...
.....I think this all comes down to proper updated training, attention to detail and taking the appropriate amount of time for the job at hand. Sometimes the damage caused by mishandling/blocking is not apparent until years later.Return to “General Boating Discussion”
