00 356, Kohler 7_3E Has mind of its own!
- Mark2000356
- Vessel Info: 2000 356 Aft Cabin
- Has thanked: 3 times
My Kohler generator has mind of its own. Some days it will run from the time we leave slip to the time return 8 hours later. Other days will run for 15 min and shut off. Some days it runs while I’m cruising, some days nope. Some days it will run when cove’d out and you guessed it, some days it will not. Acts this way whether the gas tanks are full and while their low.
Here is what I have done:
Serviced twice with oil changes and filters
New impeller
New spark plugs
New fuel filter
Next I may try a new fuel pump and new sensors. Any thoughts here... seems to be a guessing game at this point.
Thank you in advance!!! - Mark
- Has thanked: 602 times
- Been thanked: 1310 times
Re: 00 356, Kohler 7_3E Has mind of its own!
Have you noticed anything as it shuts down, like surging, or running rough etc or does it just shut off as if you turned it off at the panel ?
- Mark2000356
I would be prepared for the next shutdown with a meter to check all the sensors; oil, engine temp, water pressure, exhaust temp if applicable, and some are equipped with a low coolant level sensor.
Some other possibilities are bad/intermittent controller fuse, failing controller breaker, loose engine harness plug or corroded or pulled out pins, intermittent voltage regulator fault, corroded relay pins, loose connection or failing component in the controller.
Oh and check the Start/Stop switch on both the remote panel and the on-board one.
- Mark2000356
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
FYI, the valve is right at the top of the fuel tank, I believe, just inside the tank.
Same boat, same genset.
