Engine sync gauge vs. rpm's
Dark Horse
Vessel Info: "Dragonfly"
2001 Carver 350 Mariner
Twin 350 MAG MPI
Been thanked: 6 times
Postby Dark Horse » June 30th, 2020, 12:41 pm
The other day while taking my boat on its maiden voyage, I noticed that when the engine sync gauge was right in the middle (synced) the rpm's were off on the two motors.
If I matched the rpm's the sync gauge was off.
As this is my first boat with dual motors I'm curious to which is preferred.
And how would I correct the difference if that is in fact possible?
" The trouble with trouble is it usually starts out as fun!"
2001 350 Mariner w/ 350 Mercruisers
Home Port - Hudson, FL
Re: Engine sync gauge vs. rpm's
Postby Midnightsun » June 30th, 2020, 2:50 pm
One is obviously incorrect. Unsynced engine will not have a smooth sound, more like a hum or moaning going on. Which sounded right? Sync gauge or tachs synced?
Dark Horse
Twin 350 MAG MPI
Postby Dark Horse » June 30th, 2020, 3:28 pm
Tachs synched by far. You could hear and feel the difference and that was how I ran it.
That Being said can I correct the sync to match the tach?
Postby mjk1040 » June 30th, 2020, 8:06 pm
A mechanic told me years ago to go by the sync not the tachs. if your rudders are true straight, experiment in a open body of smooth water. If the boat veers of one way or the other your problem :beergood: should be resolved as to which is true.
