3607 Mufflers
- Winegrapewill
- Vessel Info: 1989 3607 Aft Cabin
- Has thanked: 3 times
3607 Mufflers
Thanks for the help.
Re: 3607 Mufflers
- Winegrapewill
Re: 3607 Mufflers
- Been thanked: 1111 times
Re: 3607 Mufflers
A LONG time ago I cut the 4" tubes in the middle compartment on the starboard side and under the make-up table on the port side. I installed a couple of "DAPPER" sound attenuators on each side. They were essentially about 14" long fiberglass tubes with some baffles inside. I don't think they made an appreciable difference in the sound though, but it was hard to tell as I did it over the winter and it was hard to compare the sound from one year to the next.
How are your raw water pumps?? Have they had recent major rebuilds? If you're not pumping as much water, you might have plenty for cooling but not enough to fill the pipes which dampens much of the sound.
I have also seen boats that have added 90 degree elbows at the stern so that when you're not on plane the exhaust exits below the water. Make sure there's a small hole at the top though as a "vacuum break" so when the exhaust cools it doesn't suck water up towards the engine.
- Winegrapewill
Re: 3607 Mufflers
I realize that it won't be whisper quiet with mufflers, but I would like to mellow it a little and take the rasp out of it.
There is hoses attatched in the engine compartment to the "y" that feeds down the side. I think the mufflers would just replace the length to hose behind that with another hose to the outlet attached to the transom.
The "DAPPERS" you mention sound similar to the Vernatone. Project will depend on how much cruise time as opposed to work-on-it time I can get this winter. We are year-round in California so the boat gets used year round.
Thanks for the info.
Re: 3607 Mufflers
