120VAC outlets in the engine room
- Been thanked: 1112 times
I wanted to follow up on that, because my last boat had one (that was installed post-manufacturer) and I was just on a boat this past weekend (2015 470 Sea Ray) which also had one that was obviously manufacturer-installed.
I'm wondering what the exact language is? I have an older copy of the ABYC rules and don't see anything in there. I would expect it to be covered in section E-8.15, but the only thing I see there is about putting them in areas subject to "rain, spray or flooding" and if you need to do that it has to have a spring-loaded self-closing cover.
Is there more language in later versions of the ABYC standards?
Re: 120VAC outlets in the engine room
- Has thanked: 602 times
- Been thanked: 1311 times
Sometimes with this sort of thing with regs there gets to be some assumptions that go round until they are quoted as fact, much like the double clamping rule. NOT saying this is the case at all, so stand down...
That reg book is hard to read at best and is open to opinion and some interpretation ....IMO....
- Been thanked: 654 times
I wouldn't consider the outlet a "sparking/explosion hazard" any more than the cables to the batteries, which could also spark if something is removed or reconnected. For permanently installed devices like a battery charger or space heater I could see why you'd want to discourage using an outlet and prefer a direct wire, but not sure why just the presence of an outlet (for convenience use) would be discouraged.
When someone that's aware of the dangers connects or disconnects batteries, they expect there may be a spark and so ensure that all loads are off and no fumes are present prior to touching the wiring. The average Joe wouldn't think twice of plugging something into an outlet without any forethought. It also makes it too easy to overload the circuit. I've seen a charger, hot water heater, and a trouble light hanging in the engine bay, all plugged into the same outlet on a 15A breaker. You know if there's a way, people will abuse the convenience. Oh and there's lots of room down there so let's store the outboard and portable fuel tank there while we're at it.
- KeithS
- Vessel Info: 2005 38SS
- Been thanked: 23 times
This is covered by ABYB 11.13.3.5
KeithS wrote:Source of the post Electrical outlets are allowed in machinery spaces, but if in a gasoline powered vessel they must be GFI outlets. Since no one makes an ignition protected GFI outlet, you won't find an outlet in a gas boat.
To satisfy that requirement, they could always be fed from the load side of another outlet that is a GFCI.
Poking around a bit, it seems like there is a requirement for at least a 6 lb pull test to satisfy a condition for an engine room outlet, but I see no outright ban on them in the specs.
Just not worth the chance.......IMO.
